The ordinary clock node is configured to synchronize with the boundary clock node.
The master clock port‘s (loopback VLAN) IP address in the boundary clock node is added as “unicast-master” in the ordinary clock node.
For PTP event messages originating from ordinary clocks (such as DelayReq), the ingress timestamp for updating the CorrectionField is done in the switch. So you must enable the End-to-End Transparent clock on all the egress ports. Ensure that you do not include the non-PTP capable ports in the configuration of possible egress ports through which the boundary is reachable.
